o-Ring on curved surface
Alexrose1942
Message 1 of 13
Alexrose1942
Hi
im looking for some guidance on o-ring design for curved surfaces.
the o-Ring is a shelf product (Internal diameter and thickness are known parameters) which i can model easily but i need to bend it and simulate the part running on a pipe. just not sure how to adapt it into a curved surface. (see image)
Thank you!
Replies (12)
Message 2 of 13
IgorMir
Hi Alex;
Would something as primitive as the attached IV2018 file do for you?
Cheers,
Igor.
Web: www.meqc.com.au
Message 3 of 13
Alexrose1942
Hi the part is similar to the final results. yes.
but now think about the part as something which is not curved. just an o-ring -Flat. is there kind of projection i can use that will assure that the part fit? (think about projecting 1 to 2)
Message 4 of 13
mcgyvr
bend part function will allow you to "bend" an oring to a specific single direction radius..
No "easy button" though that will just make a part deform to a more complex or any shape during assembly..
You need to either use an ipart to define its multiple shapes or derived parts or whatever..
Message 5 of 13
blandb
You can create a sketch that will be the OD/ID/CL of what you decide to sketch. 3D Sketch > Project Curve to Surface > Wrap to Face. Then Create a cross section of the o-ring and sweep cut in the profile.
New solid of the o-ring:
Autodesk Certified Professional
Message 6 of 13
blandb
You can then derive the sketches of the cut into a new part and create the bend O-ring as an independent part at that point, or keep the multi-body option. Up to you.
Message 7 of 13
johnsonshiue
Hi Brad,
Using 3D Sketch -> Intersect Curve is a great idea. A slightly more precise method is probably using Wrap option, which will preserve the length of the ring.
Many thanks!
Software Test Engineer
Message 8 of 13
blandb
That is what I was referring to. My fingers strayed from my brain....that is what I did in the picture. My apologies. Wrap to face.....
Message 9 of 13
blandb
Wait, I did state wrap to face and not intersection curve. Am I missing something?
Message 10 of 13
johnsonshiue
Hi Brad,
Sorry, it was my bad. I looked at the picture without reading the  description carefully. I thought it was Intersection Curve.
Many thanks!
Message 11 of 13
Alexrose1942
@blandb this is what i was looking for. Thank you very much!
Message 12 of 13
Hey,
I actually work on the same subject to get a static sealing between a pipe (DN100) and a tangential piece attached in the pipe. My problem is : the rugosity of a pipe is very bad, and, unfortunately, a torique sealing needs to get a great rugosity to avoid a leak. Did you find a solution ?
Message 13 of 13
memo2022
is not clear is there a video explaining in detail on fusion 360
