I have read through several posts and strings in the forums but haven't found an answer to my specific question...
When identifying a thread on an IDW drawing one may use the "Hole/Thread Note" feature and it will pull the information from the spreadsheet (located @ C:\Users\Public\Documents\Autodesk\Inventor 20xx\Design Data\XLS\en-US) and use that data for the Leader according to the "Note Format" string in the 'Style and Standard Editor'.
My questions are:
What is the "Note Format" string for NPT threads (inside of the 'Style and Standard Editor')?
Is this where NPT thread notes are handled?
I'd like to think that I can change the string formatting in the 'Style and Standard Editor' rather than alter the design data spreadsheet. The reason being, if I work on a set of drawings for my company and happen to be away on the day they are printed out or 'printed' to PDF, another user, whom opens the drawing set in question and doesn't have the same design data spreadsheet, the string will revert back to the default. (Admittedly they would also need the same Styles library to make my situation relevant, but let's assume all installs of inventor are the same and all computers have the same style library.)
