Not using all CPU power
Torben.pedersen
Message 1 of 16
Torben.pedersen
Hi fellow Inventor users.
I have the problem with inventor, where inventor is "thinking" and getting white screen, and sometimes shutdown.
when I then check the CPU use it´s between 10 and 22 % why do Inventor not use a lot more of the CPU power, and is there anything I can do, so it use more?
Specs
Processor i7
RAM 32
GPU Nvidea K2200
I hope this was helpfull.
Did I answer your question please accept this as solution.
if you liked my answer feel free to give me a Kudo 🙂
Replies (15)
Message 2 of 16
YannickEnrico
Inventor is a single-threaded application, which means it can only use one core of the CPU at any given time.
There are exceptions, though. FEA and rendering are multithreaded, and can therefore use more than one core.
Edit: See the link for an overview
https://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcartic...
_______________________________________________________________________________________
Intel Core i9-14900KF
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Inventor 2026 Professional
Message 3 of 16
Torben.pedersen
thanks for the awenser, so there is nothing to do about it ? /:
Message 4 of 16
YannickEnrico
Depending on your setup, the complexity of your geometry, the complexity of your assemblies, and the amount of constraints in those, there may, or may not be anything to do about it.
It all comes down to what small steps you can take to prevent loading times.
I can't give many recommendations when I haven't seen what's causing the problem.
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 5 of 16
Torben.pedersen
well okay, it not just 1 part/assembly
the problem is that in all the things I "draw/make" in inventor there are a lot of holes, (over 10.000) and in assembly there are parts in all these holes.
Message 6 of 16
YannickEnrico
10.000 holes... That's your problem. The geometry is too complex, even if it's just a bunch of holes. Perforation is nigh impossible to handle in Inventor.
Unless it is an absolute necessity to have the perforation on the 3D, I would create an appearance to handle it.
And then I would handle the holes on the 2D files (I suppose it's for CNC cutting and / or stamping?)
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 7 of 16
Torben.pedersen
yeah thats a lot of holes.
the problem is that our head office WILL have it all in 3D so it´s a pain in the *** most of the time.
it´s not for cutting and / or stamping but same procedure 🙂
Message 8 of 16
YannickEnrico
May I suggest that you change your workflow so you create everything without holes, and then add the holes in the end?
That way you can work with it, and when it's done and you don't have to change anything else, you can add the holes.
Your machine will thank you for that 😉
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 9 of 16
Rob67ert
If the head office likes to have it, make a small calculation of what is will cost them.
I guess they will give you a very fast PC or they change the way they think. 🙂
Robert
If you find this reply helpful ? It would be nice if you use the Accept as Solution or Kudos button below.
Message 10 of 16
YannickEnrico
I second @Rob67ert suggestion.
Get a timer app and start it every time it loads.
Do that for a week, and tell them: "I spent this much time waiting for my machine.. Because of holes... Are you sure you want for me to be this inefficient?"
64 GB DDR5 6000 MHz
2TB WD_BLACK
RTX A4000
Message 11 of 16
Torben.pedersen
the workflow wil be triggy to change, but I will keep it in mind.
yeah I guess I could time my time, thanks for the suggetions 🙂
Message 12 of 16
Ray_Feiler
Do you know which i7 you have?
See if you can find it on this chart.
http://www.cpubenchmark.net/singleThread.html
Product Design & Manufacturing Collection 2024
Sometimes you just need a good old reboot.
Message 13 of 16
Torben.pedersen
i7-4790k CPU @ 4.00GHz
why does that help me?
Message 14 of 16
Ray_Feiler
It tells us a faster CPU will not help you. Yours is currently ranked number 3 on that chart and not far enough behind the leaders to make a performance difference if you did upgrade.
Message 15 of 16
kennyj
I'm with @YannickEnrico,
Try saving the holes until the end, then roll up the end of part to just above the holes while you are working, before saving, etc.  Also look into making "Dummy" parts that are just work axis, work planes and work points aligned to your holy part (Or even create a shrinkwrapped or similar part).  Then leave that part suppressed or deleted from the assembly until you are ready to submit / vault.  Let the Dummy part align the other parts, etc.
Hope this helps,
Kenny
Message 16 of 16
Torben.pedersen
at the moment I´m already supressing the holes, but I´ll keep the other things in mind thanks 🙂
