First off I am a student, new to inventor and cad design. I am trying to make a fan adapter for a heatsink for a computer. I have searched what must be hundreds of threads but I seem to be at a disadvantage b/c I do not understand the lingo or anything other than very basic cad design. I have uploaded my file as it is now, trying to thicken the loft without screwing up the model when I go to 3d print it. I am using inventor professional 2021. This attempt may be going about my goal the whole wrong way so If I need to start over from scratch please let me know what I need to do, and what I did wrong.
Solved by JDMather. Go to Solution.
Solved by gcoombridge. Go to Solution.
@Anonymous See attached part
This is pretty tough modelling but my tips are:
Hope that helps anyway
@Anonymous wrote:
What is "shelling"?
@Anonymous
See if you can reproduce the Attached step-by-step.
as @JDMather said the shell solid is a command. By solid of three forms I was just meaning the base neck attached to the flange, the transition and the box at the top - I find it hard to explain these things verbally.
One of the most important skills with inventor (or any parametric feature based CAD) is being able to reverse engineer what has been done in a model. The tree on the LH side of the screen is like a storyboard of all of the actions in the model. Take the End of Part marker and drag it up the list and it will show you how the model develops with each feature. If there are any you don't understand double-click on them and investigate...
