Non-Uniform Force Distribution in Simulation
Hi all,
I know in previous Inventor editions it was possible to create a function to represent a non-uniform load distribution in a simulation, but I can't seem to find a method to do that in Inventor 2017. Specifically, I'm looking to perform an analysis of stresses on a water holding tank due to hydrostatic pressure when the tank is filled to various levels. Can anyone point me in the right direction?
Thanks!
swalton
To the best of my knowledge, Inventor has never been able to simulate hydrostatic pressure.
In the past, I have used the split command to create small surface regions through the depth of the tank. I then applied a pressure load (based on depth) at each surface set.
See:
https://forums.autodesk.com/t5/inventor-forum/shell-face-split-for-hydrostatic-pressure/m-p/5521500/...
https://forums.autodesk.com/t5/inventor-forum/fea-question-hydrostatic-pressure/m-p/3334675/highligh...
Steve Walton
Inventor 2025
Vault Professional 2025
You're totally right, I was confusing my experiences with Solidworks and Inventor. I'll give this a try, thanks!
TheCADWhisperer
