Non Auto-update problem
leesonghyunJNSUP
leesonghyunJNSUP
Suddenly, Whenever I use restraint function in the assembly mode, it is not reflect automatically and I can not see the result. I have to click the local update bottom to see the result.
What is the problem?
Should I re-install the inventor?
theo.bot
@leesonghyunJNSUP
I would think that the "defer update" setting is active in your assembly. If enabled, you need to update manualy after creating constrains. On the manage tab you can toggle this setting.
johnsonshiue
Hi! Yes, Theo is right. The option can also be accessed via Tools -> App options -> Assembly. When this option is on, any newly added constraint is not solved automatically until you click Update or drag a component (triggering an update) or Rebuild All. This option is meant for speedy constraint creation.
Many thanks!
Software Test Engineer
leesonghyunJNSUP
Thanks you so much! The stress is gone way!
