Node name to leader
johan.degreef
Node name to leader
johan.degreef
A have an assembly, were a valve's modified node name (model browser) has the valves TAG number.
is tere a way to reference to this nodename in a drawing leader pointing to that valve?
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
DavidTunnard
HI,
Does this help you at all? You can link this to most model properties. Press the little button with the 'X' to apply.Capture.PNG
johan.degreef
But not to the node name...?
mcgyvr
see here..
https://forums.autodesk.com/t5/inventor-customization/tag-number-in-each-purchased-item-in-an-assemb...
