New laptop performance
johan.degreef
johan.degreef
We are going to buy new laptops for our Inventor projects work and some Plant3D. The Inventor projects are very big +10.000 parts.
Will this videocard do for big assemblies?
Config ID
Product Number
Option
Description
Quantity
33234268
TC_33234268
33234268
9VE95AV
HP IDS W-10885M no WWAN Fury 17 G7 Base NB PC
1
33234268
168X0AV
Standard Packaging
1
33234268
4SS11AV
UUG
OS Localization BEL/FD
1
33234268
9UY88AV
Windows 10 Pro 64 Workstations Plus
1
33234268
9UY39AV
NVIDIA Quadro RTX 3000 6GB Graphics
1
33234268
9UZ31AV
Integrated HD 720p DualAryMic Webcam
1
33234268
9UY52AV
17.3 inch FHD (1920x1080) Anti-Glare LED UWVA 300 for HD Webcam ALSensor
1
33234268
9UZ01AV
64GB (4x16GB) DDR4 2666
1
33234268
9UZ06AV
1TB PCIe NVMe Three Layer Cell Solid State Drive
1
33234268
9UY65AV
No Near Field Communication (No NFC)
1
33234268
9UZ33AV
Intel Wi-Fi 6 AX201 ax 2x2 MU-MIMO 160MHz +Bluetooth 5 WW with 2 Antennas
1
33234268
9UY71AV
No WWAN
1
33234268
9UZ05AV
Fingerprint Sensor
1
33234268
9UY31AV
8 Cell 94 WHr Long Life
1
33234268
9UY30AV
200 Watt Smart PFC Slim AC Adapter
1
33234268
9VF03AV
UUG
C13 1.0m Tag Premium Power Cord BEL/FD
1
33234268
9VF00AV
ABB
3/3/0 Warranty EURO
1
33234268
2KY02AV
DIB No Adobe Software
1
33234268
1A225AV
AMT Enabled
1
33234268
9VF06AV
UUG
Country Localization BEL/FD
1
33234268
9VF05AV
UUG
Dual Point Backlit spill-resistant Premium Keyboard BEL/FD
1
33234268
3E756AV
Electronic TCO Certified labeling
1
33234268
3AH73AV
EU RED Pictogram Label
1
33234268
X9H35AV
eStar Enable IOPT
1
33234268
1AF06AV
Intel Xeon Label
1
33234268
ZD021A
HP Deliv SVC Door/Dock NB
1
Inventor 2025, Vault Professional 2025, Autocad Plant 3D 2025
Replies (10)
habibhamza753
Inventor really doesn't use the GPU. It's primary based on CPU. This is true for renderings aswell.
leowarren34
Hi @johan.degreef,
The card looks to be fine - the rule of thumb is that for more than 100K parts you need more than 8GB of VRAM, if run at 4K you will need more VRAM. If you want a really detailed understanding then Neil (TFI) has made an AU class on the topic of hardware for Inventor: https://www.youtube.com/watch?v=xvPX0BxljW4
@habibhamza753 You are sort of right in that Inventor doesn't use the GPU (the graphics processor) which is true - Inventor is not GPU Compute Accelerated however Inventor does need VRAM meaning you cannot disregard the GPU (graphics card) completely.
Leo Warren
Autodesk Student Ambassador Diamond
Please accept as solution and give likes if applicable.
habibhamza753
@leowarren34 True, but I do think Inventor needs to fully integrate the GPU in renderings and calculations since most GPUs have CUDA/Stream cores that accelerate in these type of tasks (NVIDIA or AMD).
johan.degreef
@habibhamza753 @leowarren34
The laptops will have this CPU inside:
https://www.cpubenchmark.net/cpu.php?cpu=Intel+Xeon+W-10885M+%40+2.40GHz&id=3762
and an NVIDIA QUADRO RTX3000
leowarren34
Hi @johan.degreef,
Overall the processor is alright - the base clock is on the lower side which may be more noticeable when multitasking with programs other than Inventor. The turbo speed is great - however do be aware that turbo can be affected by cooling and power so you may not get full speeds for too long depending on your setup. I would have a look at Plant3D requirements in case they are substantially different from Inventor.
Inventor is single-threaded for the most part (so high turbo speed is very important) so unless you use the few multi-threaded workflows inside Inventor the additional cores may not be of too much benefit - just to make you aware. However, having a few spare cores is great for background tasks so Inventor isn't having to share as much.
Leo Warren
johnsonshiue
Hi! Please see the list of Inventor operations supporting multi-core/multi-threading.
https://knowledge.autodesk.com/support/inventor/learn-explore/caas/sfdcarticles/sfdcarticles/Support...
Many thanks!
Software Test Engineer
habibhamza753
@johnsonshiue This further highlights the problem. While the things listed are important functions, Inventor needs to integrate more useful uses for multicore such as dynamic simulation and FEAs. It's common knowledge that not everyone has a CPU which can do 5.3 GHz on a single core, so why isn't there multicore functionality on such uses?
johnsonshiue
Hi! Absolutely! The more usage of MT/MC, the better. But, there are certain operations in Inventor are genetically sequential, which cannot be made MT/MC enabled.
Stress Analysis and Inventor NASTRAN are already MT/MC enabled. Dynamic Simulation is not. One thing you may consider exploring is to leverage simulation in the cloud (Fusion Simulation). You will not be bounded by your hardware. You can focus on the design tasks. For the intensive compute, send it to the cloud.
Many thanks!
habibhamza753
@johnsonshiue I see. I have a dynamic simulation which took over 20 minutes and counting and has still not finished. I'll attach the assembly below. Is there any way Autodesk could implement a cloud solution for Dynamic Simulation or is there any way I could run the simulation faster?
johnsonshiue
Hi! I am not aware of a plan to make Inventor Dynamic Simulation MT/MC enabled in the short term. If there is strong demand for that, it might be possible in the future.
Many thanks!
