NEW FILE DROP DOWN MENU DIFFERENT FROM CREATE MENU
g.vanbommel
g.vanbommel
Dear people,
I have got a problem and don't know where to search. My drop down menu to create a new file is different from the create new file menu.
All the templates we use are called standard. So that shouldn't be the problem. Also my default file locations are correct in the application options.
mdavis22569
What do you have set in your Application options?
Mike Davis
tschaeferZNBXX
If you have the file location for the default templates set correctly then it should still start by using them.  There is no way that I have found to change the wording on the drop down or fly out.
Thomas "Matt" Schaefer
Engineering Tooling and Vault Manager for Material Handling Systems MHS
*AU Speaker 2018*
* AU Speaker 2017 *
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
g.vanbommel
THNX, This the answer I needed.
