Having some weirdness with the Nesting Utility that should probably be looked at. Gist of the problem is that Inventor is trying really hard to make everything an .inest
Examples of what I'm talking about:
1. When demoting parts/assemblies, the Template selection changes to "Standard.inest" if any changes are made in the dialog box
2. When importing .stp files, the file would be imported as an .iam, but would not have the assembly environment available, only the nesting environment. Only way to get a proper import was to disable the Nesting Utility completely
3. I suspect the nesting utility might be the cause of a bad Content Center part, as after editing a custom part and replacing the family template Inventor was unable to insert the part from the CC, and I rebuilt the part only to get the same error. Once I disabled the nesting utility and rebuilt the part again I was able to get it working though
And on the topic of the Nesting Utility, but it'd be real nice if the output wouldn't just say "X many sheets of material", but would actually say "X many sheets of Y size material, etc"
Solved by bobvdd. Go to Solution.
I suspect your problems 1+2 have to do with template files that are mixed up or confused.
Could you try to reset your template files to the default situation by going to Application Options > Files > Configure Default template.
For problem 3, I would like to receive a copy of your ipt file to see if I can reproduce the problem on my end.
And on your last remark, are you referring to the plate quantity in the Report?
If so, be aware that we are planning to completely overhaul the Report to make it more user friendly and in that context we will gladly consider your suggestions for improvement.
Thanks.
Bob
I assume you mean the below options for 1 and 2? I poked around at them but there was no change in behavior, though I did realize that the import issue only seems to affect .stp files, which frankly are most of what we import.
As for 3, I went through several dozen attempts to get things working, but the 'Curved' track should be the working one that I uploaded to the CC, and the 'Curve' track being a broken one that was uploaded but couldn't be generated
Edit: It seems the forum won't let me attach the .ipt's, it's just stripping them from my post without even an error message
Send the files to my email address bob.van.der.donck@autodesk.com.
I am also curious what happens when you start a new assembly or open your default assembly template.
Do you see a nesting tab show up in the ribbon in a regular assembly?
If that is the case, you can remove nestiong data from the file by running the macro that I explained in this other newsgroup post:
Cheers
Bob
The nesting ribbon tab is visible when making new assemblies, so I imagine you're right with nesting data being tacked on. Got that macro loaded up but will probably just keep the nesting utility disabled until it's fixed/I need it again
