Hi there,
I was hoping someone might be able to help with the issues I have been having. I previously was nesting without a problem with very good results. However now I am thrown up an error/the new nest does not calculate but instead comes up with the lightning bolt error beside it see below:Any ideas on common mistakes or setting issues that would lead to these errors.
Help greatly appreciated,
Simon
This error could be caused by a few reasons. Please zip up the 5 DXF models you are using and attach them to your question. Also include a screen capture of Process Material Library and indicate which one(s) you are using, if you have move than one entry. We will be looking to the material package sizes you are assigning to each source file.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
