Nesting Utility Break Out Costs for Each Part
petestrycharske
Advisor Advisor
petestrycharske
All,
Good evening!  I have a client who is asking me if it is possible to somehow extract per part cost data from the nesting utility within Inventor 2019.  I see that there is a report, but I'm not seeing anything other than total cost and no way to easily export the data to spreadsheet format.  I admit that I've not played with the nesting utility much and am not sure what it and isn't possible.  If anyone can please point me in the right direction, I would really appreciate it.  If you have any questions, please do not hesitate to contact me.  Hope all is well and have a most blessed night!
Peace,
Pete
Just a guy on a couch...
Please give a kudos if helpful and mark as a solution if somehow I got it right.
jhackney1972
There no provided way to export the report data to any format, much less to Excel at this time.  The only way I can tell you to get a per nested part cost is to make a seperate study with just one part and get the value from the "Packaging Cost".  It is a very inefficient method but it is possible.  This field in available in the Nesting Utility 2019.1 update.
John Hackney, Retired
ToddHarris7556
What would such a cost be based on?
Todd
Product Design Collection (Inventor Pro, 3DSMax, HSMWorks)
Fusion 360 / Fusion Team
phillip.doup
Hello @petestrycharske,
Currently we do not provide these statistics, but we are working on a new report mechanism that will detail this kind of information. I cannot promise when this will make it into a specific release, but we are targeting it for the next release.
 Phillip Doup
 Architect - Fusion Platform UI
petestrycharske
Todd,
Good morning!  My apologies for the delay in reaching back out to you, but I have been working with a client the past couple of days.  I had asked myself that question, as I don't work in the sheet metal industry and haven't calculated these types of part costs before.  I guess my thoughts are as follows:
1. Calculate the area of the sheet
2. Calculate the areas of the parts being cut by that sheet
3. Ratio the areas
4. Assign the sheet costs (material, handling, etc.) proportionally to the area ratios
5. Determine if the remaining sheet material can be reused.  If not, assign the waste costs proportionally as well
Again, I don't work in that industry, but that is the first thing that came to my mind.  Has this been the approach from your experience?  I would love to know the industry standard, so I can have it in my back pocket in the even that I'm asked again.  Thanks for the feedback and have a most blessed day!
Peace,
Pete
petestrycharske
Thanks @phillip.doup!  Is this module going to be available on the Inventor Beta portal?  If so, I can try to find some time to kick it around a little bit.  Thanks for the feedback and have a most blessed day!
Peace,
Pete
AmyLiu
@petestrycharske @ToddHarris7556 @jhackney1972
NU 2019.2 is live today, issue in this post has been fixed on it. a detailed cost report on the Nesting result, you can go to Browser tree->Nesting Study->Nest->Report node, double click to open HTML Report dialog. attach a sample.
Please have a try when you get a chance. Let me know if you have any problem. thanks for your patience.
Amy Liu (cui.liu@autodesk.com)
Senior Software QA Engineer
