Nesting From a Multi-Part DXF
jmfowler1996
jmfowler1996
I'm trying to import multiple parts from a DXF into the nesting utility so that I can nest them. The DXF contains multiple parts, in various quantities.
I would like to be able to nest those parts using the nesting utility, but it seems to treat the parts (closed loops) as one joint part. It does produce a warning in the 'sources' dialog, which says "multiple parts found", but it does not treat them as multiple parts. There are a lot of unique parts, so I really don't want to need to create separate files for them all, and the quantities are already sorted out in the dxf, so using single-part dxf files would require me to apply the quantities again, which seems unnecessary (Just to be clear, I don't expect Inventor to recognise similar parts and apply quantities automatically, but just to treat each instance as a seperate part of quantity 1).
I really would have thought there would be an option for separating the parts in the dxf. Is it possible?
Thanks in advance.
AmyLiu
@jmfowler1996
thanks for the feedback.
multiple geometry are treated as a single one when do Extract dxf to Nesting. this is current behavior. We have ticket logged for the requirements that expansion of multiple shapes in dxf(TRUNINV-173).
Amy Liu ([email protected])
Senior Software QA Engineer
william
Hello Amy
Any update on this?
I have come across the same issues.
Cheers
AmyLiu
@william sorry that not support the multi-Part dxf right now.
while there is another workflow you may have a try, it is in Fusion 360 application, import the dxf file, then extrude the contour sketch to body, and create component based on body to do further nesting operation.
see an example with 2 contours in dxf file, select the contour and do extrude can generate a component, yes I agree need manual work to do it. no so straight forward.
let me know if you think it's acceptable. thanks.
william
thanks for the quick reply.
I can see how you might work around it with the workflow you describe.
Still not a great solution, with the amount of files I have to work with and the time it would take to manually process each file it just becomes impractical.
I would like to think that the developers could come up with a more intelligent solution, maybe some sort of geometry query that can interrogate the geometry in the dxf. I.e. if it is a closed contour and it is not inside another geometry - then recognise it as a part outline - add to nest study as seperate part.
AmyLiu
Understood, it's not so convenient. I will ask PM to be aware of this in the ticket. thanks for your feedback.
