Hi everyone,
I write to the next questions about Inventor 2020 Nesting and CAM modules.
1) Nesting: I working on a furniture project, creating the respective material, properties and Nesting configuration. When reviewing the Process Material Library window, the composite tab does not appear. Is it normal that it doesn't appear or is it another work configuration?
2) CAM: In the same furniture project, I have used cutting tools such as 2D contour. When making the cuts, the radius is generated in the corners by the tool used, one recommendation they gave me was to work with REST milling configuration and eliminate this material. The question is, also from changing the tool to a smaller diameter, what is the correct configuration to be able to execute this termination this area?
Thank you very much!
Aníbal
