Negative Dimension
Negative Dimension
Jose_Merino
Negative Dimension
Jose_Merino
Good morning I'm using Inventor 2016, I have a reducer that you can choose vertical and horizontal offsets, but I can make it work whit negative numbers, any body know who can i make it work with negative numbers.
Thank You.
mcgyvr
Nope.. Inventor does not support negative numbers AFAIK..
Do you really need that though? Simply flip the piece upside down.. A 5 vertical is identical to a -5 vertical
TheCADWhisperer
When you go out to the shop floor and pick on from parts bin - how do you tell them apart?
Curtis_Waguespack
Hi @Jose_Merino,
Typically when we use ilogic and need to work with negative dimensions we avoid doing so in a sketch because going past zero can cause the sketch to loose direction. Instead what we do is create work planes (offset or angular depending upon the need)  and then project those planes into the sketch. Then drive the workplane parameter with the ilogic.
Note too that I would post your ilogic related questions on the Inventor Customization forum as you will likely get those questions in front of a more focused programming audience:
http://forums.autodesk.com/t5/Autodesk-Inventor-Customization/bd-p/120
I hope this helps.
Curtis
