Need to display table for long ipart table
karthur1
Mentor Mentor
Message 1 of 22
karthur1
I have an ipart with more that 1000 member rows. I would like to see the table so that I can generate the members.  One limitation they have put in iparts is the table will only display if there are fewer than 1000 members.  In older versions of Inventor, I could add a DWORD (MaxRowInBrowser) to the proper folder in the system registry to temporarily overcome this limitation.  The registry location that I used in the past was:
HKEY_CURRENT_USER\Software\Autodesk\Inventor\RegistryVersion xx\System\Preferences\Catalog
I just tried to add this with Inventor 2018 and the "Catalog" folder is not there, so I am not sure now where to add this new DWORD.
Can someone tell me what the proper folder would be?
Replies (21)
Message 21 of 22
bieffeco
I have the same problem in Inventor 2021.1.2.
How should I proceed to view the full list of members?
Thanks!
Message 22 of 22
johnsonshiue
Hi! It should work on 2021 without the need to add the registry key. The exception is that you cannot display the browser tree using keys. It has to be member list only. You can exceed 1000 rows. If it still does not work, please send it to me directly johnson.shiue@autodesk. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
