Need help using Frame analysis
martijn.schrager
martijn.schrager
Hello everyone,
I am currently testing Inventor's frame analysis to see the displacements in drawn portals for the Dutch railway.
The calculations are currently done with MatrixFrame and the company i work for wants to switch to Inventor if possible. I have run into a problem and an annoyance...
First the problem;
A portal carries the cables that supply the train with power and as a result need to withstand a lot of different types of forces/loads. Within Matrix all forces are put into categories, such as, for example; the loads at a temperature of -20 C. A different one would be all forces that belong to the wind.
When al these categories are done and calulated, Matrix will combine them with certain factors to create maximum displacements. (I have included a picture to show an idea of what this is like)
My question is if anything like this is possible? Ofcourse i could do this by hand and just add the total to see the results. But the workflow would be a lot faster and more organised with this.
Then the annoyance:
Any time I let Inventor make a report in either PDF or Word it ruins the image only displaying half of it (as shown in picture). I'm sure that I'm probably just an idiot but if somebody knows what to do to fix it I will be forever grateful!
Thanks in advance!
Martijn.
johnsonshiue
Hi Martijn,
Frame Analysis does not deal with temperature. It uses the classic static equations and beam profile to solve the stress. I suspect you need to use Inventor NASTRAN or Fusion Simulation.
Many thanks!
Software Test Engineer
martijn.schrager
Hi Jason,
I'm not really dealing with temperatures directly nor using them. Calculations have been done as to what the weight and pressure of the cables would be in a temperature. These forces are then added to the portal normally. The problem sits with being able to combine simulations with each other and see the combinations in a report.
tobias
The calculation engine of Frame Analysis comes frome Autodesk Robot Structural Analysis.
You need this software to do what you want. It is part of the AEC collection from Autodesk.
If you press Export within Frame Analysis you get the following window:
Robot Structural Analysis Pro (RSA Pro):
https://www.autodesk.com/products/robot-structural-analysis/overview?term=1-YEAR&tab=subscription
Others:
Scia Engineer
Skyvic (Online)
Tobias
The Netherlands
Inventor Pro 2026, Vault Pro 2026, AutoCad Electrical 2026.
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
martijn.schrager
Aha, thanks!
So I'm basically using a demo version of another package thats going to cost me a kidney?
Well, now i know... I'll just do it by hand then.
Thanks again!
Cheers,
Martijn
tobias
Helaas...
Nevertheless I think Frame analysis is usefull for engineers to have a first impression of the stability of their frame design. But if you want to confirm to codes, wind pressure, safety factors are whatever, and have it checked by third parties, then yes, "insufficient".
Tobias
The Netherlands
