Need help to sketch
Need help to sketch
Message 1 of 16
Need help to sketch
Hi
Maybe it's very simpel but I don't know how to start with the sketch. I have only made the bottom.
The Tips means: draw these two sketches on the top and extrude down
To information I use Inventor 2017.
Thanks in advance!
Replies (15)
Message 2 of 16
JDMather
Attach the *.ipt file here of what you have attempted so far.
Message 3 of 16
mdavis22569
You can do it a few different ways
1) Make it how it would be machined, starting with a sq or rectangle block
2) Make it from the side profile of section A-A  and cut it as needed to make it look like the picture
3) Make the bottom, put a rectangle block extrusion on that and continue modeling
If it was me, I'd do 1, but I've been on Inventor and designing for a long time.. a newer person would start with 2 or 3
Just my opinion..
Mike Davis
Message 4 of 16
How did you determined the angles/slopes? Isn't there only two angles, 10 deg and 15 deg?
Message 5 of 16
JDMather
See attached.
Message 6 of 16
SBix26
... and here's a slightly different way to tackle it.  Warning: everything is in one sketch, a practice I normally try to avoid and don't recommend, but this particular part seems to just beg for that approach!
Sam B
Inventor Professional 2017 R3
Vault Basic 2017.0.1
Windows 7 Enterprise 64-bit, SP1
Inventor Certified Professional
Message 7 of 16
JDMather
@Anonymous , after viewing Sam's solution I realized that I made a mistake on one of the dimensions in my "solution".  I'll let you figure out which one.
Message 8 of 16
Sofia.Xanthopoulou
Hi @Anonymous,
how far did you come with the advice given. Post your feedback, so we know how to support you.
Could you figure out JDMather's brainteaser? Smiley Wink
Happy New Year!
Message 9 of 16
I have made the attached before I have seen your comments. I think it looks correct
Message 10 of 16
Sofia.Xanthopoulou
Well, @Anonymous,
maybe you want to reconsider ...
Happy New Year!
Message 11 of 16
The distance/dimension 17,5 you have measured is the little square. The one i have attached on my first post it is measured from the outside/the biggest square.
I have illustrated on the attached in this post.
Message 12 of 16
How can I change the // 0,1 A on the right side without delete the most of what I have created?
Message 13 of 16
Sofia.Xanthopoulou
Ok, that measurement was my bad Smiley Sad
For the parallel flange you could use  the Face Draft Feature or maybe a chamfer.
Regards
Message 14 of 16
Really thanks for your help!
If I use draft what should the degree be?
Message 15 of 16
Sofia.Xanthopoulou
As it has to be parallel to the oblique line it should be 10°. Maybe you have to delete the fillets 2 and 3 and recreate them.
Regards
Message 16 of 16
Sofia.Xanthopoulou
Hi @Anonymous,
mission accomplished ? Smiley Happy
If so, please mark at least one solution or post the solution, so that other readers can benefit from your results.
If you need further assistance on this, please continue the conversation
Please create a new thread for other questions
Thank you
