Announcements
Need help to sketch - sauce boat
Hi
Is there anyone how can help me to sketch this sauce boat?
I hope it is the right forum I ask about help. If I should ask in another forum or website then let me know 🙂
Thanks in advance!
Replies (13)
asiteur
Oke, I added numbers in the picture below.
In short: I would loft the cup structure, then the handle using a separate loft. Cut out the bottom with a sphere
1) Start by making a plane at a 5 degree angle, 90 mm away from the origin P1
2) Create on this plane the profile of the top of the cup, and on the base plane the bottom of the cup
2b) In the perpendicular plane, make the rails (specified in the pic with C and D crosssections)
Now Loft the profile using the Guide Rails
3) Cut out a sphere on the bottom
4)Draw the top and bottom profile in separate sketches, draw a rail and LOFT
Then you can constrain them together
I hope this helps!
Am I making your school assignment here?
Alexander Siteur
Project Engineer at MARIN | NL
LinkedIn
All what I ask in this forum is not my assignments. In each semester we have test in inventor and last semester I get a very low grade. I asked my teacher to get my old drawings I can practice.
But how can I make a plane without start to sketch?
asiteur
Use 'Angle to plane around edge' select for example the XZ plane and then the Z-axis. Now we create another plane offset from this plane.
This is a very basic question you ask. If you have trouble with the basics you'd better work yourself through a set of tutorials, there are plenty. This seems like a simple mug but lofting is always a bit tricky, so you should improve your skills.
Alexander Siteur
LinkedIn
TheCADWhisperer
Attach the *.ipt file of what you have attempted so far.
@TheCADWhisperer @asiteur and others
Is it not possible to start sketch the outer form?
I've tried but it seems to be wrong..
How to dimension the sides in the blue and green boxes i have attached here? I have also attached what i have tried to sketch.
Thanks in advance!
TheCADWhisperer
Can you attach your *.ipt file here rather than mere images?
asiteur
HI,
Oke to give you a quick start, I made a screencast:
http://autode.sk/2mzc9Qe
It's a bit slow and as you can see I also make mistakes/find out that my first approach doesn't work. If you follow these steps you'll at least be able to get the basic shape.
You will need some refinement afterwards such as the 30 degree angle. I didn't have time to do it all
Alexander Siteur
LinkedIn
Hi
I have first found time to take a look at your video now. I had tried the same as you.
When I make the projekt geometry  there appear a circle instead of a line. In addition I can't make the loft.
When it is best to make the section view C-C ?
Thanks in advance!
asiteur
It depends on how you look at it, and in which planes you work what the projected geometry will look like.
If you change view to 'front' and use the XY plane instead of YZ you'll get what I got.
So for the section CC, make that right at this stage.
But if you want to loft, whatever you do, you need to be 100% sure that the vertical rails are connected to the profiles top and bottom, cause right now they aren't.
Alexander Siteur
LinkedIn
If I select the XY plane instead then I can't make the sides/borders.. 😕
The attached is from the ipt file in the previous post.
Should they (sketch1, projekt geometry and spline from sketch3) not be in one point?
Hi Again
I have solved it.
The only thing I'm missing back now is the detail in section D-D (handel). To this it wil be very nice with some help!
Thanks in advance!
asiteur
Well done! Please have a look at my handle attached.
Best,
Alexander
Alexander Siteur
LinkedIn
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
