Hello to all:
I need some help modifyng INV models of conveyor beds. When they were originally done, they weren't designed as having separate Solid Bodies. Now (in order for them to be used in SketchUp fpr visualization) I have go back through all these .IPT's and make them so they will export to AutoCAD as logical groups of separate entities (see the attached AutoCAD file of a slightly different bed).
I have attached three files:
- one of the original .IPT,
- one of the failure to make the rollers behave as separate Solid Bodies
- An AutoCAD file of a slightly different bed that will show what I need as an end result
THis bed does have a parmeter for resizing it's width, so if you'd like to take a crack at helping with this, please be sure the bed resizes its width correctly with your adjustments. Thanks very much in advance!
