I would greatly appreciate anyone who can help me out here.
So I made two plastic parts that will assemble into one case. Because it will be for an injection mold I need to draft it.
I first made the parts like A in the picture.
Then by using face draft I drafted both sides using the same angle values.
However they do not line up like shown in C.
I am assuming this is because the left part and the right part have different lengths.
1. How do I get it to line up like B? Can it be done by using the face draft tool?
I imagined using either loft or tapered extrusion as a solution but the shape is complex and would like to avoid it and use face draft tool if possible.
2. The black line is the base of the case so I would like it to be flat. Are there any work around for this kind of situation?
IF there is no other way but to draft it.. can I give it less than 0.5 degrees? (It is about 40mm deep and the wall is 3mm thick)
