Inventor Forum
Need help filling a weld in a weldment.
3 REPLIES 3
jeanchile
860 Views, 3 Replies
Hello everyone,
I am currently working on a weldment for a bearing and have a question about the weld in the picture attached. How do I get the bevel weld on one side of the radial lip to fill the way I need it? If I select "Radial Fill", I can't select a fill direction. If I select a fill direction, I can't get the weld to fill radially (unless I create three different welds).
Any tips/suggestions?
Inventor Professional
3 REPLIES 3
JDMather
in reply to: jeanchile
Can you attach the assembly here?  (I guess I could make up a quick dummy assembly - but I am feeling lazy today.)
Can you use the Split (Face) command to isolate the face you want welded?
Well, now it looks like I wasn't so lazy after all and not alone on that count.
yannick3
Hi
The only way is to split face,create construction plane and use split feature.
Yannick Verreault
INV PRO 2015
MS Office 2007
Win 7 pro, core i7 950, asus P6T WS
nvidia Gforce GTX 295
WD caviar black 500Go
WD caviar black 1To
jeanchile
in reply to: JDMather
Umm... Yes. Yes I certainly can. Smiley Embarassed This is only the third model I have done where I needed to show the actual welds and I'm a little embarrassed I didn't think of that.
Thank you JD (and Yannick) for the (now obvious) suggestion. Please enjoy the rest of your weekend and tell your bosses I said you get a raise.
