The backstory:
I am a fresh graduate in mechanical engineering and I have been working for a machine shop for about 9 months now. I am very familiar with 3d modeling as far as generating a model, applying materials, and generating assemblies. What I haven't had much experience with is managing a large project with 10+ main assemblies and each of those having multiple sub assemblies. My supervisor who is the lead engineer has worked here for over 30 years, but is still using autocad lt for all of his work and he has never used 3D cad or even upgraded to full blown autoCAD.
Basically we have a project now in which a parent company is supposed to give us all of the models and assemblies that I can use to make cut lists, fabrication drawings, and machining drawings. The problem I am having is the models and assemblies aren't finished even though it's running at 8 months past the point we were promised to have it. We are using the fusion team cloud based system (because vault won't work for them for what-ever reason) for managing the files as of the past 2 weeks which shows that even the parts and assemblies that were said to have been completed have changed 8-9 times just in the past couple of weeks which makes any drawings I have made questionable at best. To add to this there are things like materials being set wrong, none of the dimensions have been saved consistently as iproperties for ideal BOM management, and the project's ship date hasn't budged at all. I have tried to bring up the issues with the model with nothing really being done about them.
TL-DR: Poorly managed project using inventor and no current system/workflow to follow because my current engineering lead is only used to autocad lt.
I feel like learning to code VBA will help quite a bit, but can't find much in the way of resources even on the forums. The link to Thalheim's book doesn't seem to be active anymore. I was wondering if there was any advice or resources or classes that I could be turned to in order to develop my own work flow as far as managing an inventor project of this size? I have also been making my own standard templates for idws to streamline the drawing process which has helped, but I still feel like there is so much more I need to figure out.
I apologize for such a long post, but I am just starting to feel like I'm drowning and no one at the company seems to be concerned all too much with it, so I am trying to just man up and do what it takes, but it seems like I'm not making any real progress.
Kameron Williams
