Inventor Forum
Nailboard View Grayed Out
2 REPLIES 2
RussellD3HV32
341 Views, 2 Replies
Hi All,
Im working on a couple nailboard drawings that are very similar. (Same connectors, same general tables, parts lists, etc).
I deleted the old nailboard view, saved as my next drawing file name, and now I cannot import another nailboard.
Must I redo all the work for the same result?
Thanks, Russell
Labels (3)
2 REPLIES 2
Hi Russell,
It looks like a bug to me. Nailboard command should always be enabled when "Routed System: Cable and Harness" add-in is loaded. If you restart Inventor, does it come back?
Many thanks!
Software Test Engineer
Hi Johnson,
I got the error to repeat upon restarting the application.
I seem to have found a workaround and if that I start a nailboard from a base drawing, instead of nailboard for the Cable and harness tab in my assembly, that I can swap different drawings in the same 'nailboard'.
Thank you.
