Multiple parts
Multiple parts
Multiple parts
I am making a acrylic panel, but right now I am making one by one, is there any way to set it so I can make 10 or so at a time?
mdavis22569
more info need ....
Can you share an example
Are they all the same?  Are you in an assembly making them ?
Mike Davis
Lets say I have a piece 20x20 to make 10 2x2 panels, at the moment, I am
running one, then moving my x,y and running another. Is there a way to
program it so I can run multiples at the same time without manually moving
it over?
Jonathan Campos
Engineer
Paramount Panels, INC
909-947-8008 ext. 232
jonathancampos@paramountpanels.com
Curtis_Waguespack
Hi jonathancamposXU6D8,
If I understand correctly, you should be able to use the Rectangular Pattern option of the Pattern Components tool:
http://help.autodesk.com/view/INVNTOR/2015/ENU/?guid=GUID-AFAEC6D0-BBAB-474F-B467-4F3E676BC4AF
I hope this helps.
Curtis
