Multiple parts in the same parts list
olekristen9
olekristen9
Hi, I want to place multiple baseviews on the same sheet with different parts and I also want them to all appear on the same parts list. Is there any way to do that? I know I can edit the parts list and just type in the information, but I need to have the parts linked to the parts list.
Thank you for your time in advance.
mdavis22569
You're best bet then would be to make an assembly with all the parts from that sheet.. and then make a parts list from that assembly. You don't have to put it in the drawing, just pick it ... but if you feel you need to put it in the drawing, you can put the view out in space and move it off the sheet as a reference.
not the best way but it works
Mike Davis
olekristen9
Thanks for replying, and with the new knowledge I found an even better way to do it 😉 You can choose to make a parts list of the entire assembly instead of just the small assembly I made with just the parts from the base views I placed in the sheet. And after you get the parts list with every part, you can filter out the parts you actually want to show up, Edit parts list -> Filter Settings and filter out based on Item Number Range.
