Long story short, someone who is no longer at our company had a method of making drawings that we're trying to get away from. I have to revise a drawing very quickly, though, and don't have time to redo the views he made, some of which are off the edge of the drawing, linking back to views on the visible part. The file size is also huge, so I'm going through and adding levels of detail (LODs) to make it possible for any computer in our department to hopen the file. The problem is, there are two independent views on the same sheet and when I change the level of detail on one, it changes the other. Please note these are NOT dependent or linked to each other in any way. Is this something that can be turned off so I can have multiple LODs of the same assembly on the same drawing sheet?
Thanks!
I hope I am understanding your question. You can only assign a LOD to a Base View in the drawing. You can have more than one Base View per drawing so you can have different LOD showing. Projected Views from each Base View acquire the LOD of their Base View independent of the other Base Views on the drawing. See the Screencast.
"If you find my answer solved your question, please select the Accept Solution icon"
John Hackney
Retired
Beyond the Drafting Board
You may have better luck if you use Design View Reps, not LODs to manage object visibility in drawing files. Use the RMB on a LOD in the model browser to copy that LOD to a design rep. You can filter Parts Lists by Design rep, but you can't by LOD.
LODs were useful to reduce the memory demands of large iam files, but they didn't help much with drawing files. Remember, each LOD shown in a drawing is an additional copy of a portion of the original iam file. It can add up.
I'm actually surprised that you have not had issues saving the drawing file when you have views with different LODs shown. Do you have the source .iam file open at the same time?
Steve Walton
Please post a screencast and your assembly, using Pack and Go to include all parts, so the forum can see and test what is happening. What you describe should not be an issue.
John Hackney
Retired
Hi! The behavior does not sound right to me. Any drawing view can reference any assembly LOD independently. Unless the two views have parent-child relationship, changing any view setting in one view should not affect the other.
I will need to see the files to comment further. Please feel free to send it directly to me (johnson.shiue@autodesk.com).
Many thanks!
