Multiple Draft Angles For Embossed Element on Complex Curved Surface
I'm pretty new to Inventor, having recently moved over from Fusion 360, where I'm at an intermediate level. I have a challenging problem that I'm not sure how to accomplish.
Problem:
I am preparing a model for injection molding, and the part is going to have a logo embossed in it. Because of the way the part is made, it needs to have a draft angle just off of the vertical axis. However, because the logo is oriented ~30 degrees off the vertical axis, this results in a sharp edge and concave hollow on the top of the logo.
Here is the base part I'm working with:
I need a way to create multiple drafts on the embossed shape, so that the bottom edge of the embossing extends down to the part surface vertically, and the top edge extends to the part surface horizontally. In this image, I have drawn the two draft angles in blue and red, with an approximation of the intersection with the base part drawn in green:
The part is a revolved shape, not a simple curve, meaning that I can't use regular embossing methods. My solution was to split the surface of my target body using the logo, and then use the thicken function to create an emboss.
However, now that I've done that, Inventor won't let me modify the drafts of of my shape. I get the following error message when I try to apply a draft to any of the faces:
I tried sweeping the Logo solid, but I get an error message with that too. I'm not sure what to try next.
imajar
I'm sorry, I cant tell what you are asking.  Can you attach  your attempt here and a different description?  I cant tell what you are describing in the image with the saw teeth.
I think the basis of your question is how to emboss something in the direction of pull of the mold, yes?
Aaron Jarrett, PE
Inventor 2019 | i7-6700K 64GB NVidia M4000
LinkedIn
Life is Good.
johnsonshiue
Hi! Drafting may not work reliably on this kind of cases. Try using Ruled Surface command. Pick the top edges and have the surface angled from the side faces. You may need to extend the ruled surfaces. Lastly use Sculpt to join it to the solid body.
If it does not work, please share the file here.
Many thanks!
Software Test Engineer
