- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
We are making the switch from Solidworks to Autodesk Inventor on the moment. In the middle of the switch I will starting up a project without Vault and I was wondering if you can make a multi user environment in Inventor without Vault. Back in the days we did use the multi user enviroment in Solidworks.
This function basically means that the R/RW modes will handled by Solidworks instead of the windows file system. In your tree you can mark to individually parts/sub-assemblies which should have write rights. With this enabled you can work in a sub-assembly (on other parts) at the same time.
Is there something similair in Inventor ?
Link copied
