Multi-level Terminals, Autocad Electrical and Inventor
aschenk128
aschenk128
Has anyone had any luck getting Electrical and Inventor to work with multilevel terminals? Specifically getting the electromechanical link to work? I also cant export an harness data xml file from Inventor. Says it cannot create the file. Not sure what the issue is. We are using Electrical 2019 and Inventor 2019. Have things been improved in 2020.
Andrew Schenk
Electrical Designer
mcgyvr
I'm just hanging out for the knowledge... Don't mind me..
I did find this.. Maybe it will help..
https://forums.autodesk.com/t5/autocad-electrical-forum/electrical-terminal-symbol-attribute-for-ele...
aschenk128
I did find this link in my searches. I tried that method with the same result. I get the same errors as the author.
Andrew Schenk
Electrical Designer
lena.talkhina
Hello @aschenk128  !
Great to see you here on Inventor Forum.
Did you find a solution?
If yes, please click on the "Accept as Solution" button as then also other community users can easily find and benefit from the information.
If not please don't hesitate to give an update here in your topic so all members know what ́s the progression on your question is and what might be helpful to achieve what you ́re looking for. 🙂
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям! | Do you find the posts helpful? "LIKE" these posts!
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
Лена Талхина/Lena Talkhina
Менеджер Сообщества - Русский/Community Manager - Russian
aschenk128
Lena, I found solutions but not one that will work for me.
Andrew Schenk
Electrical Designer
aschenk128
I didnt get it working with the multi level terminals, I did get it working with the single levels.
Andrew Schenk
Electrical Designer
