Multi Body Solids not Show all body in drawings
I will explain this as best i can. I have a multi body part from a customer to use in a layout. Only problem is that when i place this item into a drawing it does not show all the parts
when i place in drawing i get
I can not figure out why this is not showing the Whole part in the drawing. If i go to Solid Bodies it shows that over half of them are invisable but if i right click it will not give me the option to turn them on again.
Curtis_Waguespack
Hi acritchelow,
I opened the part file and placed a drawing view of it on a new drawing and saw the results that you did. Then I did a Rebuild All from the part file, and went back to the drawing and it was showing all solid bodies as expected.
I hope this helps.
Curtis
Marco.Takx
Welcome to the forum.
I didn't chech your part because I'm on my mobile.
But are those missing Parts (Solid Bodies) surfaces??
If so, then you have to go to the browser and right-click on the part in the view and select include surfaces.
See the link for more information.
Include Surfaces in drawing
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
That did the trick!
Thank you!
