Moving from SolidWorks to Inventor, Need some tutorials and tips please!
I have been working with SolidWorks routinely for a while. I am now moving to a new employer who uses Inventor. I haven't been able to find a good source of basic tutorials to get me going.
Is there a good source that is usually recommended to get someone started in becoming efficient using Inventor? SolidWorks has a large database of MANY different people and great instructional videos on YouTube. Not so much on the Inventor side.
Thanks!
mdavis22569
Use the 30 day trial of the software at home ..
They have built in Tutorials of all different levels within the software now.
There are some good ones (and horrible ones) on YouTube
Look at some of the re-sellers they have tons of videos online as well to watch and see how things are done.
and then there is this forum where we help each other
Mike
Mike Davis
JDMather
http://forums.autodesk.com/t5/inventor-forum/skillsusa-document-now-on-screencast/m-p/5856691#M56480...
https://www.youtube.com/channel/UCF7zEkelSRiHB1rOnspaBgQ
Niel cross has a good youtube channel to learn from its called tfi
Cadmanto
If you do searches on these forums, and on Youtube as well as the built in tutorials, there should be plenty of info to help you transition smoothly.
This topic comes up at least 4-5 times a month.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
swalton
I like @PaulMunford and Paul Normand's Mastering Inventor 2016 book
http://www.wiley.com/WileyCDA/WileyTitle/productCd-1119059801.html
or
https://www.amazon.com/Mastering-Autodesk-Inventor-2016-LT/dp/1119059801
Steve Walton
Inventor 2025
Vault Professional 2025
