Moving Drawings from AutoCad to Inventor
Message 1 of 10
Hi all,
When I copy drawings from AutoDesk, and simply paste them inside an Inventor the sketches are sometimes scaled with conversions which I assume are iches to mm. (factor 25.4:1).
For some projects I want to copy a sketch from Autocad, paste them in an Inventor sketch then extrude them to create my 3D model. Yet I encounter the scaling problem. (I do not want to use the scale tool because I require dimensions to be exact, NOT 'close to'). Additionally some sketches which are joined in autodesk become unjoined when copying, which creates issues for me when I want to extrude.
What I've tried
  • Creating New Part.ipt(mm) [Ensuring that units are all mm]
Replies (9)
Message 2 of 10
Xun.Zhang
Hello Philip,
Perhaps that the drawing in AutoCAD do contains a scale factor, so how about to make the scale in AutoCAD as 1:1 firstly and then copy-paste to Inventor 2D sketch?
By the way, how about just create it in Inventor from scratch.. Its good practice. Additionally, there are many ways to handle the transition such as create a sketch and insert the DWG file to 2D sketch or Copy AutoCAD data into 2D sketches or leverage DWG Underlay technology to do so.
Hope it helps!
Xun
Message 3 of 10
jhackney1972
If you make sure your Units in AutoCAD are the same as your Units in your part template in Inventor and then you only draw to a 1:1 scale in AutoCAD, you will never have an issue.  Take a look at the screencast where I set the units to millimeters in AutoCAD, draw a 1:1 drawing and then copy and paste it into Inventor.
John Hackney, Retired
Message 4 of 10
TheCADWhisperer
Check your EXISTING dwg in AutoCAD with the command -dwgunits (be sure to type the preceding dash as shown).
What does the command line report as your current document units in AutoCAD?
Message 5 of 10
TheCADWhisperer
If you still have trouble - Attach your file here.
Message 6 of 10
Don't waste your time trying to bring in AutoCAD Sketches. It will only give you headaches.
Best practice is to model your parts in Inventor. It's a great way to learn the software and will give you better models.
You will learn design intent.
Autodesk sells you that you can easily do this, it's not true.
Message 7 of 10
Frederick_Law
There is an option to combine points when import sketch.  SolidWorks exported DWG/DXF will have point not connected, event they have exact same coordinate.  Its a default setting in SWX that need to be changed.
Scale will give you exact dimension if you type in 1/25.4 as scale factor.  Or 10/254 in AutoCAD.
Unless you draw the DWG drawing, don't assume its correct.  Check every dimension to the drawing.  Too many user cheat on AutoCAD.
Message 8 of 10
hncarle
Ok off on an alternate tangent. LOL
When you import AutoCad stuff into inventor it comes without any scale.  Take a known dimension and put it onto the drawing.  The figure will automatically scale to match that dimension.
Have you noticed when you start a sketch without dimensions and later add them the sketch sometimes MOVES?  That is from the same thing.  The sketch will scale to the dimension.
Message 9 of 10
Frederick_Law
It may not work, depends on the profile and constrain.
If some of the end points are not connected, it will tear the sketch apart.
I had Inventor sketch not scale with dimension before.
Also with unconstrained import sketch, its easy to accidentally drag and move something.
I usually fix everything first then measure.
Message 10 of 10
kelly.young
Autodesk Support
Autodesk Support
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
Were you able to get your AutoCAD files to work within Inventor with any of the proposed suggestions?
If you want to attach the files here or record a screencast showing what you are experiencing that would be helpful for community members to comment further.
Please select the Accept as Solution button if a post solves your issue or answers your question.
