I have an iam with a circle attached to a corner part with screw holes in it (1st attachment). It was derived from an ipt (2nd attachment).
1. What's the best way to move the circle 2 mm closer to the corner part?
2. How do I make the uom mm instead of inches? The size of the parts are correct if they were in mm. As it stands now I need to multiply by 0.03937 (1/25.4) when I export the part for printing.
Solved by JDMather. Go to Solution.
Hello @inventabuild ,
Not sure which one is the corner part and the the direction when try to move the circle part, could you clarify a bit more.
For the unit setting, you can go to Tools -> Document setting and set the unit as mm.
Hope it helps!
Hello, please let me know if the attached snippet gives enough information about the circle to move and its direction.
There are numerous issues indicated in your history tree ( i in circle ) and an extraordinary amount of extra work.
If I give you step-by-step instructions, are you willing to follow my steps and learn how to use Inventor (or any CAD software) correctly?
Before we begin - I must warn that this could take several weeks.
I see that you have been using Inventor for 4.5 years and you will likely have to "unlearn" previously used techniques to then learn my techniques.
It will be a couple of hours till I get out of my current class to post the first step.
Q1. What is the source of the stl file that you started with (designer and software used)?
Hello, the original stl came from here: http://devel.lulzbot.com/TAZ/Olive/production_parts/printed_parts/bed_corner_taz6/bed_corner_taz6_v2...
I don't know which software was used, but I'm sure it was some open source program. Thanks.
Hi! You could use Move Bodies command (Modify -> expand it -> Move Bodies) and select all solid and surface bodies to move closer to the origin. The issue is that even after you do that, the sketches will be still located far away.
You should have moved the Composite surface using Move Bodies before you started further modeling.
Many thanks!
I started with an stl, converted it to base and built solids on and around it. I don't understand how I could move the parts separately to the origin.
What are you attempting to model?
The assembly that you attached is missing the parts that it references?
I uploaded the original part also when I uploaded the assembly.
I copied pasted the parts into the assembly.
I don't know what this means?
I can obviously see everything that you have uploaded here.
Where have you uploaded Solid8.ipt?
Where have you uploaded Solid9.ipt?
Where have you uploaded Solid10.ipt?
Do you see these files uploaded in to this thread?
Do you see these files in your project folder (do you have a project folder)?
Have you had any training involving Inventor assembly file structure?
Do you have a photograph of something similar to what you are attempting to model?
Can you find a link in the internet to an image of something similar to what you are attempting to model?
Hello JD,
Thanks for your replies.
1. I uploaded the Solid9.ipt and Solid10.ipt in the first post contained in the bed_corner_taz6_v2_modified_for_fsr_9mm_legs.ipt (see first and second attachments of this post for reference).
2. I uploaded a picture (3rd attachment) of what the part looks like, but the part in the picture has the circle too far away and needs to be moved closer as I explained in a previous post.
@inventabuild wrote:
Hello JD,
Nope.
You never uploaded your Solid9.ipt or Solid10.ipt.
That should be obvious.
I don't think I will be able to help from a remote location.
Did you look in my part "bed_corner_taz6_v2_modified_for_fsr_9mm_legs.ipt" in my first post. That's where solid9 and solid10 came from. I never had separate ipt files for solid9 and solid 10. They came from the "bed_corner_taz6_v2_modified_for_fsr_9mm_legs.ipt" file that I posted on my first post.
Does that help you find the solids 9 and 10?
1. Did you look in my part "bed_corner_taz6_v2_modified_for_fsr_9mm_legs.ipt" in my first post.
2. That's where solid9 and solid10 came from.
3. I never had separate ipt files for solid9 and solid 10.
4. They came from the "bed_corner_taz6_v2_modified_for_fsr_9mm_legs.ipt" file that I posted on my first post.
5. Does that help you find the solids 9 and 10?
1. Of course I did, this isn't my first rodeo.
2. And I know that is where they came from - you did a Manage>Make Components to push out the parts and assembly.
3. Your assembly file that you attached says differently - I already posted image of this fact in Post #10.
4. Yes, they came from that file, but you never attached them here.
5. No, because I don't have access to your computer to find them.
I could push them out again from the multi-body file, but Inventor would toss an error because the assembly points to ipt files that are on your drive. Again, this isn't my first rodeo.
Let's start back at the very beginning.
Attach your original stl file here and I will create video of how to correctly import the geometry.
Thanks JD, attached is the stl that I started with.
Thanks JD,
Attached are Solid8.ipt, Solid9.ipt and Solid10.ipt
