I have a 3D sketch of a rectangular block which was initially 40 mm high. I extended it by 20 mm by extruding 10 mm on the top face and 10 mm on the bottom face. I had sketches on the top and bottom faces of the original block for inserting holes. The sketches are now buried between the faces and the extrusions.
How can I move the sketches to the surface of the extrusion without having to delete and redraw the sketches? I tried copy-paste without success.
The bottom extrusion occurred below the z-axis working plane but I would prefer to move it to the surface of the z plane (i.e. move it upwards by 10 mm in the z-axis). Is there a way to do this?
Thank you in advance.
Solved by tsokadev. Go to Solution.
Solved by hermitch. Go to Solution.
Did you try project geometry of the old sketch to the new face / height?
You should either modify the base-sketch/-extrusion of the part prior to adding the sketches that are now obsolete
or try "Move Face" or "Direct Edit" (will be the same face-index) instead of Extrusion (adding volume and creating new a face-index).
cheers
@mdavis22569 wrote:Did you try project geometry of the old sketch to the new face / height?
Thanks for your response. Unfortunately, the extrusions on both the top and bottom faces disappear when I try to edit the sketches, which makes it impossible for me to project the geometry.
Can't turn on the visibility?
@hermitch wrote:You should either modify the base-sketch/-extrusion of the part prior to adding the sketches that are now obsolete
cheers
Thanks for the hints. I deleted all the sketches and used Move Face to add 10 mm to the top and bottom faces. After that I used Move Bodies and moved the body up by +10 mm in the z-axis. This solved the problem.
Cheers
