actually, you can select the entire spline w/ a bounding box, then move the cursor over the spline so it turns red, then LMB and hold and drag. It is kind of finicky, but if you get it just right, when you drag the cursor will change to a "drag hand" and you can drag it like Al said. No explicit Move command though.
