Mouse Hover Not Selecting Parts in Assembly
chrisw01a
Message 1 of 12
chrisw01a
Inventor 2021 and 2022.  This just started happening a couple of weeks ago.  In an assembly, when you hover over a component, it should immediately highlight that component and then if you click, it will be selected and change color (green in my case).  For some reason, mine is not highlighting on hover.  If I click, it will still be selected, but nothing changes state on hover.  Sketches are fine as lines and dimensions are highlighted as soon as the mouse pointer touches them.
Is there a setting?  Very annoying and I hope you guys have some suggestions.
Video attached.
Thank You!
Replies (11)
Message 2 of 12
Gabriel_Watson
Please test if Tools (tab) > Application Options > General (tab) > "Enable Optimized Selection" helps you or not.
Edit: Tools (tab) > Application Options > Colors (tab) > "Enable Prehighlight" should be on.
Message 3 of 12
CGBenner
@chrisw01a
Chris Benner
Message 4 of 12
chrisw01a
Tried that and did not change anything.  Thank you.
Message 5 of 12
chrisw01a
Haha! Got it. Any I bet when I installed 2022, it copied the setting...
Thank you!
Message 6 of 12
Suba_Ruthiran_N8JPLEND9XP4
Community Visitor
Community Visitor
I cant select a part from assembly. I left click my mouse button on the parts of assembly but nothing gets highlighted and cant open the model from there.
Message 7 of 12
SBix26
Can you do a screen capture to show what's happening?  Better yet would be a video.  Hard to diagnose without more information.
Sam B
Inventor Pro 2024 | Windows 10 Home 22H2
Message 8 of 12
johnsonshiue
Hi! Try resetting Inventor. Go to Inventor Reset Utility -> reset all the Inventor settings back to install default.
Many thanks1
Software Test Engineer
Message 9 of 12
jgarrettXK33T
Community Visitor
Community Visitor
I've just upgraded to Inventor Professional 2026 and I'm experiencing the problem described here, but the solutions presented here have no effect. Hovering the mouse over model components in the model tree used to highlight the components in the working window. How do I restore this hover-highlight feature?
Message 10 of 12
johnsonshiue
Hi! I could be wrong but I think the behavior you want to enable is indeed called Prehighlighting. Go to Tools -> App Options -> Colors -> check "Enable Prehighlighting."
Many thanks!
Message 11 of 12
jgarrettXK33T
Community Visitor
Community Visitor
Thank you. The feature is working properly now. Restarting the program might have made the change take affect.
Message 12 of 12
chrisw01a
Try restarting your computer.
