MOTION ON A FLIGHT PATH
a.amirNVP3B
Message 1 of 16
a.amirNVP3B
Hi all,
can anyone help me to constraint the scraper onto the flight. The scraper has a pivoting point at the top. I really need to know whether the scraper my clash in between the shells. The
Please find attached the screenshots.
THANKS IN ADVANCE.
Replies (15)
Message 2 of 16
Michiel.Valcke
Message 3 of 16
a.amirNVP3B
I tried but it did not work.
Anas.
Message 4 of 16
JDMather
@a.amirNVP3B
I would use Environments>Dynamic Simulation for this analysis.
Message 5 of 16
Michiel.Valcke
Does your joint have enough freedom to compensate for the lateral move of your scraper?
Message 6 of 16
johnsonshiue
Hi! I believe Transition Constraint should work as long as you limit the transition scope using a surface body. Please share the files here.
Many thanks!
Software Test Engineer
Message 7 of 16
a.amirNVP3B
Here is the model.
I tried Environments>Dynamic Simulation to do the analysis, I did not find a solution yet.
Message 8 of 16
johnsonshiue
Hi! The iam file isn't enough. Please use Pack&Go to ensure reference all files are included in a folder. Zip them and attach it here.
Many thanks!
Message 9 of 16
a.amirNVP3B
hi, sorry 😅.
here is the pack&go file.
Thanks.
Message 10 of 16
johnsonshiue
Hi! Many thanks for sharing the files! I took a quick look. Indeed, there is already a surface body in the sheet metal part. However, Transitional constraint (and all other assembly constraints) work between two different components. The transition will only happen between two selected components.
In your case, you will need to have one part with all of the loft surfaces combined together. Then the scrapper transits on the combined surface bodies.
You could easily do that by saving the current assembly as a different assembly. Next derive the new assembly to a part (include only the surface bodies). Then use Stitch command to combine all surfaces into one quilt. Place the derived part into the old assembly. Add the transitional constraint between the scrapper and the quilt surface. It should work.
Thanks again!
Message 11 of 16
a.amirNVP3B
Hi, I tried what you proposed, it should work logically but I get the error window ("The assembly cannot be solved").
I tried to reduce the scraper arm's length for it to fit in the locus of the path, but it gives the error window and when I accept the relationship the shaft does not rotate nor the scraper swings.
If I send you the files I modified, would you be able to try and see if it works?
Thanks.
Message 12 of 16
JDMather
@a.amirNVP3B
I do not own a license to a rar extractor.
Can you Attach *.zip file instead?
Message 13 of 16
johnsonshiue
Hi! Yes, absolutely! Please share it here or send it to me directly ([email protected]). I would like to understand the failure better.
Many thanks!
Message 14 of 16
a.amirNVP3B
Hi Mr Johnson,
sorry for this late reply. I will send you my model in a bit.
I worked on a solution but I need to add a constraint to the scraper so that it stays within the two shells where the path is. instead of having fixed hanger the support, I made the point of support a pivoting point so that each time the scraper comes to contact with the shell, it rotates so that it continues its way. I cannot figure out the right constraint to use, while I constraint the end part of the scraper tangentially to the shell it does not work.
Find attached a video of the solution I am working on.
If you could suggest something I would be grateful. Thanks.
Message 15 of 16
a.amirNVP3B
Hi, I could not save *.zip. Can I have your email please? I will send you the files directly.
Anas.
Message 16 of 16
johnsonshiue
Hi Anas,
Many thanks for sharing the files! I took a quick look and modified the  model a little bit. It should work better now.
Without disclosing the design detail, I can share some comments regarding this issue. It is a combination of Tangent constraint and Transitional constraint leading to reduced DOF. To make Transitional constraint work, it is better limit the scope of transition. Use a small sphere or a surface to transit over the target face.
Tangent constraints can be replaced by Mate constraints or Flush constraints whenever it is applicable. Tangent constraints are better used when the components are not connected to other components. Otherwise, the DOF can be significantly reduced.
Thanks again!
