First of all I know this posting is already out there but this has nothing to do with Dell Data so I decided to log a new one.
The other day (as you can see if that other posting).. Had a 2017.4 installation failure that was related to the Tutorial Plug-in and I had to use Microsoft Fixit to remove that plug in to allow the Inventor 2017.4 installation to complete
Today two (2) more machines failed the update and this time it was related to Autodesk Desktop Connect Service application. So that application was uninstalled and the installation still fails. Currently we are going to check again using Microsoft Fixit to ensure it has been fully removed and reboot the machine just in case "stuff" was left over in memory. What a pain..
Mark Lancaster
& Autodesk Services MarketPlace Provider
No luck.. Keeps failing in the same spot and this Design Connect Service application is not even installed.
@DannyHubbard or @johnsonshiue Any thoughts?
I can send you the logs if you want..
Mark Lancaster
Hi Mark,
Please send me the log files.
Many thanks!
Last week I sent you an email with logs. Did you get it?
Mark Lancaster
It seems like this has been an ongoing problem... I just tried it today for the first time and got errors on multiple attempts. Turned off Webroot and had no luck. I'm not about to go messing with uninstalling add ins or getting IT involved or spending days debugging. If I can't just download and install an update without it taking half a day or more, then I probably don't want it.
Anyway, has anyone figured out why this is such a problem? Yes, I can send you log files.
My point is that a lot of users when they run into this sort of thing will just get mad and give up.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
After playing with this on and off all day, Stopping and restarting the Windows Installer service SEEMS to have fixed the issue... so far. I'm still watching the little blue progress strip so no promises yet.
Chris Benner
Hi Chris,
Based on the discussions from the two following threads, the install failures seem to be caused by external factors that Inventor does not have control over.
Are you using Cylance PROTECT?
Many thanks!
