So I was looking into creating a custom content center library for the company I work for. It is strictly for Frame Generated structural members, so your beams and channels, ect.
There are 4 things I want to accomplish with this.
1.) Material defaults to appropriate designation. (A36 for W-beams, A500 for HSS, ect.)
2.) Length Parameter exports as Architectural Units. So a channel of length 20.5 inches would export as 1'-8 1/2"
3.) Add an iLogic rule to modify part length string if there is a leading 0 for inches. (say my part is 12.5" long. Even if I correctly change the export property for the length variable above, it would show up as 1'- 1/2". I need it to show up as 1'-0 1/2". I wrote a rule to do this for normal parts, but I need to add this to the content center parts as well)
4.) Description modified to show material, Member type, size and length, all formatted correctly.
5.) Change the unit quantity to each instead of length. So that 20.5" channel would show up on the BOM as (1) unit of a 20.5" channel.
Currently I am manually doing this for every member I use in Frame Generator. It is manageable, but not ideal. Mistakes are made, parts are missed or partially completed, and the drawing's BOM is off.
Currently, I am able to do 1 & 4, but 2, 3 & 5 are eluding me. Is there an .ipt file somewhere I can modify? Or am I going about this the wrong way, and I should be exploring an iLogic rule that runs from the assembly level and makes these modifications?
See attached images if it's unclear what I am looking to change.
Jacob
