Model states issue/bug
c_caronBJVAW
c_caronBJVAW
I recently noticed an issue with the model states, where every time I modify something in the spreadsheet controlling the different model states, when I come back to the ipt everything is fine but when I look at the dwg of that part, all mirrored elements disappear. This happens even if I don't modify anything. The only way to correct it, is by suppressing and un-suppressing the mirrored elements.
Is this a known bug?
Are there any ways to stop that from happening?
Thank you
kacper.suchomski
Yes, this is an error from the "no automatic update" category. I hope they fix it in future releases.
Kacper Suchomski
c_caronBJVAW
Ahh thank you!
johnsonshiue
Hi! The behavior sounds like a bug to me. If possible, please share an example that exhibits the behavior here. I would like to understand the Model States update issue.
Many thanks!
Software Test Engineer
c_caronBJVAW
Sure how could i share an example? what do you need to see?
-Charles
johnsonshiue
Hi! Please share the Inventor files (iam and ipt) in zip here, or send it to me directly johnson.shiue@autodesk.com. I would like to understand the behavior better.
Many thanks!
c_caronBJVAW
All right, Ill just have to check with my superior, if i am allowed to do so.
