The part created by the component generators does not have the ability to use the "Model State".
This applies to both the Shaft component generator and the Gear component generator at least.
The issue was found in versions 2023, 2024, 2025 with the latest program updates.
Is it possible to add a "Model State" branch in the browser for such parts?
Do you find the posts helpful? "LIKE" these posts! | Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням!
Have your question been answered successfully? Click "ACCEPT SOLUTION" button. | На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ"
Gelöst! Gehe zur Lösung
Gelöst von CGBenner. Gehe zur Lösung
@Alexander_Chernikov
Hello. According to this article, Model States do not work with Design Accelerator components. I believe the same is true with Routed Systems such as Tube & Pipe. I hope this helps to explain.
Chris Benner
Industry Community Manager – Design & Manufacturing
If a response answers your question, please use ACCEPT SOLUTION to assist other users later.
Also be generous with Likes! Thank you and enjoy!
Thanks for the reply and the link.
It's a pity.
