hi
for school I need Inventor 2018. I installed the student version but when it's fully installed, no shortcut is shown on my desktop and there is no way to make one that works myself. I have installed and deinstalled inventor for a couple of times now but it just does not work. Can someone please help me with this?
thanks
kelly.young has edited your subject line for clarity: missing shortcut
Hello @Anonymous I see that you are visiting as a new member to the Inventor Forum.
Welcome to the Autodesk Community!
There are many ways to setup shortcuts, easiest I can think of can you find the program in the start menu?
RMB (Right Mouse Button) > Open File Location
If it takes you to the shortcut screen, RMB > Open File Location
RMB > Send to > Desktop (create shortcut)
Hope this helps!
Please select the Accept as Solution button if a post solves your issue or answers your question.
* Ideas * Help * AKN * Updates * Pack & Go * Reset Utility * Repair Install * Customization * iLogic Examples * Autodesk University *
@Anonymous can you run a search for inventor.exe then open file location?
or just go through the windows explorer to the location:
C:\Program Files\Autodesk\Inventor 2018\Bin
It should be within its own folder within the Start>Programs inside the "Autodesk" folder.
