Mirroring iFeature (spline) has strange results
lselter6PKDY
lselter6PKDY
When trying to mirror an iFeature (exploded involute spline) I get very strange results.
I have attached a video of the issue. Does anyone have a solution, or is this a known issue
Running inventor 2023.
johnsonshiue
Hi! This might be a bug in the way the iFeature was created or it is a Mirror Feature bug. Please share the files here. I would like to understand the behavior better.
Many thanks!
Software Test Engineer
lselter6PKDY
I have attached an assy and two parts one where I have exploded the spline feature, but it behaves the same in both cases.
johnsonshiue
Hi! I believe this is a combined issue of the Mirror feature and the Involute Spline feature. I don't see a good workflow mirroring the geometry as features. I am wondering if mirroring the solid body will work better.
Edit the Mirror feature and change it to Mirror Solids -> New Solids. The result will be a new body symmetric to the source body. Then use Combine -> Intersect to merge the two bodies.
Is this what you were looking for?
Many thanks!
lselter6PKDY
yes it would be possible to use the mirror solid but this would add quite a lot of extra features to achieve what could have been a relatively simple operation.
In this case I was trying to get the tooth run-out on both ends, would it be possible to add this as an option in the spline tool?
