Mirror Problem
Mirror Problem
ilker_akay
Mirror Problem
ilker_akay
Hello, I added a video about the problem. I want to mirror a part in assembly. It looks correct in the preview. After applying the command, a different view appears. I've never encountered such a problem before. What could I be doing wrong? Or maybe there is a problem with the settings? The version I am using is 2024.2.1
admaiora
Hi @ilker_akay
That part can't be actually simmetric with the same code, it needs to be another mirrored part on your disk.
Admaiora
_____________________________________________________________________________
Facebook | Twitter | Youtube
ilker_akay
 Hi,@Admaiora
Unfortunately, the options there do not change the result.
Even if I try to draw a simple piece from scratch, it gives the same result.
The piece is not mirrored, it is rotated 180°.
The preview always shows correctly but the result is different.
I think there is a problem with the settings or an update problem.
ilker_akay
The problem is caused by Vault. When you disable it, there is no problem.
The apparent problem is; new filenames automatically use existing ones without adding -MIR. If we fix it manually, it appears as a new file. I added a sample video.
