Mirror Constraints for Parts
MikeKovacik4928
MikeKovacik4928
When you mirror a part in an assembly, all constraints are lost on the mirrored part.
Unless,of course, you choose the option to "ground mirrored parts"
Now if you want the mirrored parts to be constrained in a similar manner to the
original parts, you have to reconstrain them all over again.
There seems to be  no "mirror" constraint for parts.
(ie similar to symmetry constraint for geometry, but
constraining a part symmetrically about a mirror plane to another part, so that if the
original non mirrored part moves, so will the the "mirror Constrained"
Part)
Does this exist? Is there a way of doing it using standard Out of Box Inventor
What does everybody else do when it comes to mirroring parts and reconstraining them.
This is very time consuming unless you choose the "ground" option, which is not always
what you want.
Michael Kovacik
AutoCAD 2d & 3d (29 yrs)& Inventor (7 yrs)
Manufacturing (30 yrs) Draughtsman
Autodesk Product Design Suite Ultimate 2018
Johannesburg, South Africa
Autocad 2018, Inventor Pro 2018
(and recently Autocad Customisation)
(Impossible only means you haven't
found the solution yet)
jtylerbc
In my opinion, it should simply (automatically) apply Symmetry constraints to the origin planes of the mirrored parts, about the mirror plane.  That would essentially be a "mirror constraint", as you described it.
As-is, for the most part I don't even bother with the using the Mirror Components tool. Since it requires you to manually constrain the mirrored copy anyway, it doesn't really do anything all that helpful.
In some situations (if the parts themselves are symmetric), you can use Circular Pattern (2 instances, 180°) to approximate what a properly designed Mirror Components command should do.
Various versions of fixes for this have been posted to the Ideas board.  You might want to go vote for one (or more) of them to show your support for adding this functionality.
https://forums.autodesk.com/t5/inventor-ideas/improve-mirrored-parts-add-option-to-ground-mirrored-c...
https://forums.autodesk.com/t5/inventor-ideas/treat-quot-mirror-quot-in-an-assembly-like-a-pattern-m...
https://forums.autodesk.com/t5/inventor-ideas/mirror-assembly-improvements-append-symetric-constrain...
There are probably more - those are just the relevant ones from the first page of search results on the Idea board.
MikeKovacik4928
Thanks John
I have gone on to the ideas section you pointed me to, and cast my supporting vote.
It seems many users over the years have spotted this and are wanting this done.
It is a great idea and soooo logical.
Lets hope it gets implemented. Hundreds of experienced Inventor Users worldwide can't be wrong!!
Michael Kovacik
Manufacturing (30 yrs) Draughtsman/Designer
Impossible only means you haven't found
the solution yet
Type a product name
______
icon-svg-close-thick
Cookie preferences
THIRD PARTY SERVICES
icon-svg-hide-thick
icon-svg-show-thick
Qualtrics
Akamai mPulse
Digital River
Dynatrace
Khoros
Launch Darkly
New Relic
Salesforce Live Agent
Wistia
Tealium
Upsellit
CJ Affiliates
Commission Factory
Typepad Stats
Geo Targetly
SpeedCurve
Qualified
icon-svg-hide-thick
icon-svg-show-thick
Google Optimize
ClickTale
OneSignal
Optimizely
Amplitude
Snowplow
UserVoice
Clearbit
YouTube
icon-svg-hide-thick
icon-svg-show-thick
Adobe Analytics
AdWords
Marketo
Doubleclick
HubSpot
Twitter
Facebook
LinkedIn
Yahoo! Japan
Naver
Quantcast
Call Tracking
Wunderkind
ADC Media
AgrantSEM
Bidtellect
Bing
G2Crowd
NMPI Display
VK
Adobe Target
Trendkite
Hotjar
6 Sense
Terminus
StackAdapt
The Trade Desk
RollWorks
Your experience. Your choice.
