Mirrir Pattern
Mirrir Pattern
lkirit2000
Advisor Advisor
Mirrir Pattern
lkirit2000
Hi
Please see the attached image , the slots in the below are mirrored from top. Once dimensions are updated from top edge of source slots, the mirrored sketches haven't been updated !
Please let me know what went wrong ?
Rgds
Xun.Zhang
Hello @lkirit2000,
Have you checked the Rebuild all firstly?
Upload the part please.
Xun
lkirit2000
Hi Xun,
I have refreshed but not working.
I sent the part to your e-mail address.
Rgds
Kiri
Xun.Zhang
Hello Loganathan,
I don't see mirror constraint at all, are you sure you have apply the mirror constraint before?
Xun
johnsonshiue
Hi! Make sure you click the Update button after you make the change in the parameter or the sketch. Another possibility is related to Derive not properly pushing the change from source to derived part. You will need to install 2019.4 to have the fix.
Many thanks!
Software Test Engineer
lkirit2000
Hi Johnson,
Thanks for your response. I am going to install 2020 version soon.
Is it fixed in  Inventor 2020 ?
Rgds
johnsonshiue
Hi! The derive update issue will be fixed in 2020.1 (like in 2019.4). But, I am not sure if your issue is the same. Could you share the file here?
Many thanks!
