Announcements
Milling or engraving fonts
I purchased a hobby engraving/milling machine, (3040) cheap but good enough for me to play with.  I have the 2.5D profiling and milling working quite well with HSM but am struggling with text.  From reading a few posts, it seems I need to drop it into AutoCAD and convert to single line text of a suitable line font which is a PITA.
I was wondering if anyone had a library of letters created with arcs lines etc that I can pocket, or better yet some code that i can select the mill diameter and create these pockets using a text editor, (something that recognises a character and replaces with said pocket)
otherwise a single line type font that I can put on my sketch and then use the trace tool and set my depth manually
Many thanks
Marco.Takx
Engraving is something that is within Inventor HSM Beta version now.
Engrave
I don't know if this will be implemented within the HSM Express version.
Met vriendelijke groet | Kind regards | Mit freundlichem Gruß
Marco Takx
CAM Programmer & CAM Consultant
thanks, i will take a look at this.  do you know if it does true type fonts?
Marco.Takx
Hi Stephen,
Yes that is possible.
Marco Takx
looks good, unfortunatly it appears the beta test is no longer availiable
Marco.Takx
Like I said, I don't know if this will be availible for Inventor HSM Express.
If you are using a Inventor HSM or Inventor HSM Professional you have the possibility to install the latest development (Beta) versions.
Marco Takx
