Mill/Turn Post Processing
creocatia3d
Message 1 of 16
creocatia3d
how to reposition the UCS?
Accepted solutions (3)
Replies (15)
Message 2 of 16
creocatia3d
Is there another way other than cube view?
kelly.young has edited your subject line for clarity: How can UCS Change
Message 3 of 16
kelly.young
Autodesk Support
Autodesk Support
@creocatia3d here is a previous post with many responses that might give you more information that you need, but probably point to what you're looking for. Hope this helps!
UCS
Please select the Accept as Solution button if a post solves your issue or answers your question.
Message 4 of 16
Mark.Lancaster
@creocatia3d
It appears you are referring to a CNC package/workflow..  What CNC package are you using for Inventor?  If its Inventor HSM, this product has its own forum.
Mark Lancaster
Message 5 of 16
johnsonshiue
Hi! I am sorry that I don't understand the question. ViewCube helps you see the geometry in different pre-defined view angles. UCS is a concept of coordinate system. If you wan to create your own coordinate system, you can use UCS command in part or assembly.
Many thanks!
Software Test Engineer
Message 6 of 16
Mark.Lancaster
Johnson
There's another posting about this. I think OP is looking to change UCS in a cnc operation. I'm in mobile mode so unable to link to the other Inventor Forum posting.
Mark Lancaster
Message 7 of 16
creocatia3d
but what?
typing UCS in mode .ipt and nothing
Message 8 of 16
johnsonshiue
Hi! I think you misunderstood UCS command. Here is some documentation about UCS.
https://knowledge.autodesk.com/support/inventor-products/learn-explore/caas/CloudHelp/cloudhelp/2018...
Please feel free to go to Autodesk Knowledge Network to find relevant information. There are a lot of valuable instructional documents and videos.
Many thanks!
Message 9 of 16
kelly.young
Autodesk Support
Autodesk Support
@creocatia3d could you provide a screenshot or .ipt you are working on for better clarification?
We can definitely help you get your view/ucs orientation solved but need a bit more info to identify where the confusion is. Thanks!
Message 10 of 16
creocatia3d
Yes.
super useful this tip!!!!
thank you
Message 11 of 16
creocatia3d
but I noticed that the viewcube does not follow a new position.
http://autode.sk/2y47PuM
Message 12 of 16
jtylerbc
UCS and View Cube are completely unrelated concepts.  You seem to be thinking of UCS in Inventor as functioning similar to the way it does in AutoCAD.  They are actually very different things in the two programs, which unfortunately share the same name.
In the past in other systems, I have seen objects like the Inventor "UCS" referred to as a Local Coordinate System (LCS) instead.  I think that would have been a better name in Inventor as well, because it wouldn't carry over misunderstandings for people coming from AutoCAD.
Message 13 of 16
mcgyvr
Did they already mention what CAM program they are using?
If HSM there is no need to "reposition" the UCS/viewcube in the normal "Inventor ways"
In the initial setup of the HSM job you simply pick where you want the XYZ origin to be and can easily/quickly change that right there..
@creocatia3d What cam program are you using?
Message 14 of 16
creocatia3d
OK Alright
I thought that while changing the UCS the viewcube would accompany.
Thank you
Message 15 of 16
creocatia3d
I only thought about changing due to the presentation of the tool working
on the screen.
It is opposite to the modeling mode that I make.
(TOP, FRONT, LEFT) and not (TOP, FRONT, RiGHT)
thank you
Message 16 of 16
jtylerbc
@creocatia3d wrote:
OK Alright
Thank you
There is still a bit of a terminology problem going on here, I think, and probably still a misunderstanding of what a UCS in Inventor actually is.  From what I can see, you're not "changing the UCS" at all.  In your Screencast, you created 3 separate UCS's on different corners of your model, and at no point did you ever change any of them.
The UCS in Inventor is a model feature, just like a work plane, axis, extrusion, etc.  It is not an abstract working view orientation concept like in AutoCAD - it is a persistent object in the history of your model.  Essentially, it is a collection of three work planes, three work axes, and a work point, and you can create as many of them as you want.
