migration needed
migration needed
a.omassi
migration needed
a.omassi
Hello and sorry if I can't explain my problem well but my Inventor is in italian.
I need to update the title block because whe ghange the image logo on it, but when I use the automatic exchange procedure when i select the destination file I have some popup that tell me that not every file is elegible because they need to be migrated... any suggestion on how to solve this problem?
Is there a way to this procedure on all the files of the project at the same time without having to select every single file digging in every folder?
Thanks so much for your help
mcgyvr
If you have files that need to be migrated you can use the Autodesk Task Scheduler to perform the migration across multiple files/folders.
Its installed with Inventor and located in the Autodesk folder in your start menu/program files list
johnsonshiue
Hi! Brian is right. You can use Task Scheduler to migrate files in a batch. Also, you want to migrate the styles library using Styles Library Manager. You don't want to create new drawing on an outdated Styles Library.
Many thanks!
Software Test Engineer
